Script for Autoit lan connection
Hi, Doroti Davis,
If you want to check auto it LAN, You may follow the following process :
· If you want to see that is my PC/Laptop are connected to the network. You may check it –Click Start Menu- click –Run-Type- ping- space – type your IP address press Enter if replies come from your network it seems your LAN is Ok.
· If your server doesn't respond you may check it to type- ping – space-server IP address and press Enter. If the reply comes that you seems your server is OK but if reply come that time out you will seem that your server is not OK.
· If you want to reply come all times you may type after IP Address space than-t Enter.
Thanks
Amos Marie
Hello Davis,
Thanks for your quest. I think focusing point of your question is setting up scripts and checking audit LAN connection. I like to say you to notice three important points. These are respectively typing code, exe file and compilation and coordination. Let me explain a little more. You need to put error free code while running Script editor, then turns to exe file for compiling. Next look for effective coordination of your clicking. When it is done, checking Auto LAN connection will take place. I hope your server will tune with your work. If it does not do so, please contact them.
Notifications
