A script for automatic update calendar 2011.
Hello friends,
A script for automatic update calendar 2011. The company needs a java department store system that has this feature of automatic update in the calendar that will generate all the sales report for the day together with the date and main event of the day. I want to get some java coding technique about the issue, or any video tutorial will do which is related to any department system regarding calendar updates.
Thanks and Regards,
Christine Turner.
Answered By 5 points N/A #165489
So you need to make this using a java. But this is not a best option to do this even you cannot do this using html. I suggest you to use php for making a script for updating a calendar automatically. You can do this excellently using php.
But I can give you a tutorial which can teach you how to do this.
Clue: You can use data() function to get a present date. Then you can add the calculation date using auto update script.
To get a tutorial, please go to the link which I have given below.
https://villavu.com/forum/showthread.php?t=70271
