Script compressor wav to ogg technique
This days am working on a multimedia project and am looking for script compressor wav to ogg, also i want to ask if in case of compressed wav or other format to ogg will this effect on the quality of the audio file?
I will be thankful if anyone can explain to me in general how this compression works, am interesting in knowing the technique.
Answered By 10 points N/A #172206
Hi Matthew,
I am trying to help you to solve your problem. Here is my suggestion.
OGG file format is better then the other file format. It use low space between wav file. If you compress wav to ogg file format.
This will better for quality ogg file format is better then wav. Ogg file is use low disk space and give us better quality sound to listeners. Ogg file format is very compatible with MP3 file format.
But it has two problems one is, Ogg file format is difficult to burn to audio cd and second one is this format is not supported on iPod.
Thanks
