Script Error when trying to convert PDF file
Previously, when I have some documents which I need to convert to a .pdf file, I just need to right-click my mouse and then select Convert to PDF. Just today when trying to perform this feature, an error message stops me from doing it. It stating that the error has occurred in the script on the page (Line 11; Character 3; Error-Permission denied; Code – 0. It then asked me if I wanted to continue running the script with a selection of Yes or No. I clicked on Yes the first time but it does not solve the issue. Afterwards, I select the No, which just shows no effect. How can I fix this?
Answered By 0 points N/A #121842
Hello Hillary
On the pdf provider component will make files availability. This means you should create page setup first. On your pdf might establish over data for doing. So it will not work as you want.  At first delete the whole content on your pdf converter. Then run your system. Re-start your computer. if you press the yes it working but it must set up the page set up option there it shows on pages problems an error will occur there. take only one configuration file
Nor press No option. All the content should same writing code as per supporting files. This will help you. Thanks
Answered By 590495 points N/A #342911
That error is with the program you are using to convert your file to PDF. Make sure you are using an administrator account when running the program. If this doesn’t help, try running the program as admin. Right-click the program in error and select “Run as administrator” then see if this helps. If this doesn’t help, try reinstalling the program.
Download the free version of Revo Uninstaller and install. Once installed, start Revo then select the program in error among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and click to delete everything it finds. This removes everything the program created on your computer.
When it is finished, exit Revo then install the program back. If the problem continues, use an online converter. First option is Online PDF Converter. You can upload your files in four (4) ways: Dropbox, Google Drive, URL, and selecting it from your hard drive. Second option is Free PDF Converter. Third is Convertio PDF Converter.
All three online methods allow you to download the file immediately after conversion. They will not require you to enter your email address for the converted file.
