rearuiz
Posted on - 12/14/2011
I am currently facing problems with my computer system. I am getting the first error message when I dial while the page is loading. The error message that’s says, ‘Error happened in the script page line number, character number. Access denied. Code number and a URL.’ Then it will ask ‘do you want to continue’. I don’t know what option is to be given. The second message says that ‘Acrobat Internet Explorer helper. Internet explorer.exe software error. Please help me to solve both issues. I will be thankful for all the help and support.
Script Page Error and IE.exe software Error
The first error message that you are receiving while accessing a website using the browser that you have installed is because of a bug in the browser, and thus you will need to do the following:
When the error message asks you if you want to continue with loading the page, click yes to continue. If the bug is not tragic, the website will load properly.
But in case the bug leads to your website crushing, then you will need to reinstall the browser again to fix the issue with the bug.
As for the second error message with adobe acrobat, it is the application that is corrupt, and therefore you will need to perform a reinstallation of the adobe acrobat reader on your computer to fix the problem.
Regards
Thompson Locker
