Script to upload images into website.
What is the script that allow to upload images into website and what is the perfect language to create this script?
You can use PHP image gallery script,this will allow you to show your images online and eventually you can sell some of your images by using this software in the future.
The PHP image gallery script,this type of scripts are used on three main areas, one is the server side scripting, it means the most traditional and main target field for PHP.second is the being the command line scripting ,which means that it can run without any server or browser and lastly is using it for writing desktop applications,meaning it is not the best language to create a desktop application but if you know very well your PHP script you will have the ability to write different programs.
