SCSM 2012 Analysis Library – Error opening excel file. Please help!
Hello everybody,
I started to explore Analysis Library and set up folders to store OLAP data Excel files. As I try to open files that are saved in a library folder it gives me the error given below within the SCSM 2012 RC console.
"Error: Object reference not set to an instance of an object (see screenshot below)"
If I close this error it seems work well and the excel file will open.
Here is the error by text.
Date: 2/21/2012 1:48:53 PM
Application: System Center Service Manager
Application Version: 7.5.1464.0
Severity: Error
Message: Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an object.
  at Microsoft.EnterpriseManagement.UI.SdkDataAccess.ConsoleTaskHandler.DoTask(IList`1 navigationNodes, NavigationModelNodeTask task, List`1 parameterList)
  at Microsoft.EnterpriseManagement.UI.SdkDataAccess.ConsoleTaskHandler.DoTask(IList`1 navigationNodes, NavigationModelNodeTask task)
  at Microsoft.EnterpriseManagement.ConsoleFramework.WindowJobRecord.ExecuteBackgroundJob(Object sender, ConsoleJobEventArgs eventargs)
  at Microsoft.EnterpriseManagement.ServiceManager.UI.Console.ConsoleJobExceptionHandler.ExecuteJob(IComponent component, EventHandler`1 job, Object sender, ConsoleJobEventArgs args)
Thanks for all.
