Sculptris software is unsupportive with windows XP
Hello experts,
I have installed VirtualBox on my Windows 8 (x64) and I have installed Windows XP on a Virtual Machine. Now when I try to open a software named Sculptris this error box appears and it fails. I did some searches on the Internet and nothing useful found. Does anyone have an idea how this error can be solved and what this error means ?
Thank you !
Failed to init extensions. New graphics drivers might help.
Answered By 10 points N/A #192284
Simple XP installation won’t help you. You need to install service pack-2 on top of your XP operating system. If it is already installed check that you at least have 1Ghz Pentium 4 or above processor family available in your PC. RAM requirement for this resource hungry software is 1 GB or more. The most importantly ensure that you have proper graphics card available with your hardware to support this software. As per specification you need ATI or NVidia card with openGL 2.0
