SD back up program running in Window 7 corrupted.
Hi to all, I would love to see my favorite SD back up program run in Window 7 OS. I have a computer that runs on a dual booting of vista and Window 7. I got a little messy with it in the vista version and now it has been corrupted to that window and cannot be reinstalled it back.
What should I do?
Any suggestion would be much appreciated.
Error:
Error Number:0x80040703
Description:Failed to find DLL function:sfc.SRSetRestorePoint
Setup will now terminate.
Answered By 590495 points N/A #144874
Since your SD application got corrupted using it under Windows Vista, why not completely uninstall it from your system then install it back. Doing another clean installation of the program will install a fresh copy of the application and will also remove possible corrupted files in its installation.
Uninstall SD from your machine then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, or Norton SystemWorks. Install the program again after this and see if it works.
