Sdhc card file recovery from htc desire
How much HTC Desire will be beneficial for sdhc card file recovery if I want to recover data from htc desire?
The HTC Desire can be used to recover files from sdhc card. To do this you need to download a software called HTC Media Recovery. Follow the steps below:
1. Download the software and install it on your computer. You can download the software here.
2. After installing the software open the Media recovery tool.
3. Now connect your HTC Desire to the computer using the USB.
4. Then click the Start Scan button by selecting your drive.
5. After the scan is complete you can view all the deleted files, pictures, etc. Click on the Recover button.
Hope this information helps you.
If you have a microSD card and you need to format it for use on your phone, the recommended way to format it is from your phone and not using a computer. If you want to format it using the computer, you can use a program called SD Memory Card Formatter. Just download and use it to format your SD card.
But if you want to recover deleted files from your memory card, the recovery should be done using a computer. To recover files from your memory card, your computer should have a memory card reader. Laptops normally have a memory card reader. If you have one, use it to access your memory card.
Download PC Tools Performance Toolkit. Follow the instructions to download and unpack and then install it. Once installed, insert your SD card into the memory card reader then run PC Tools. Go to “Recovery” tab and click “Recover Lost Files.” On the next screen, configure the recovery options then click “Start Scan” to scan your SD card.
