larryiresto
30 points
Posted on - 12/10/2012
I want to find availability of software development kit for explorer and if any sdk explorer available from the system developer can I download it via internet? And also please tell me the instructions to run that program on windows. Thanks Â
SDK Explorer Software Development Kit and Instructions on Running the Program
The System Center Service Manager 2010 Software Development Kit (SDK) can be downloaded from Microsoft’s website. You can run the exe file. By opening  SDK.chm file you can have documentation.
SDK version 3 is also available and you need Windows Server 2003 ,System Center Configuration Manager 2007
Microsoft Visual Studio 2005
Microsoft Management Console 3.0
Microsoft .NET Framework version 2.0 Â in order to download that.
You can run the program after downloading it. Â Download the ConfigMgr2007SDKv40.exe file and unzip the contents to a temporary folder. Run Configuration_Manager_2007_SDK_Setup.msi to install.
