SDK ( Software Developer Kit )
When I make use of this SDK (Software Developer Kit) Pitch Helix rule in Inventor 2012 64-bit, I get an error.
Has anybody else met this error message? Have you got a result? I understand these are unconfirmed Add-ins, however I am confident that somebody may have a response.
I have maintained the orders in regards to making the planar sketch holding a circle. Also,I have checked all 3 planes. However I have checked using a Work Axis as well as the Default Z-axis.
I cannot choose the circle by picking on its diameter or center point, when encouraged to choose the profile.
 But when I choose the Axis key, the error happens. I think this occurs for the reason that the Profile collection is not pleased.
The Inventor fixing has been effectively creating pieces for almost a year, however the initial time via the Pitch Helix device from the SDK.
Also I have added a picture of the total Details from the error message dialog box. I expect it is supportive.
Need a solution of this error. Please help.
Thanks a lot.
