Search PPT to DVD type commercial tool
Hi all, Is there any tool that will convert Power Point Presentation to Video,
Please help me to search PPT to DVD type commercial tool that will help me.
Thanks,
Abelina Sophia
Thanks,
Abelina Sophia
Hi Abelina!
Although you can manually convert your PowerPoint presentation to a video, a DVD type, there are also different software that can help you by doing this automatically.
The Movavi is a good converter, free to download either for Windows or for Mac. It helps you also to save the PPT presentation on a DVD-compatible format, so that you can burn them on a DVD. Moreover, if you convert it into a video, you can put it even on your mobile phone. It has over ten output formats, amongst which you can see AVI, MPEG, MP4, MKV etc.
Still, if you decide to use a manual way of doing things, you have here an YouTube tutorial and a step-by-step guide from the Office staff.
Good luck!Â
