Hello Experts,
I am working on multi resolution formats. I am searching for the best image tile compiler because I already tried many image tile compilers available on line. But they did to give better results. If you now any best image tile compiler then tells me about it.
Searching for best image tile compiler
Hi there Chloe,Â
Tilling images can be very challenging and you definitely need tools to help you with this task. Which programs online have you tested?
I've tried "Tiled Map Editor" before for my gaming project and it worked like magic.
You can download this amazing tool. You just need to choose which machine are you using (Windows, Mac, Linux).
This tool comes with an XML – based map format and supports orthogonal and isometric maps.
Hope this helps your problem and enjoy tiling!
Waall Mike
