Searching failed in msn messenger screen name
Search option in my msn messenger is showing some problem. When I am going to search msn messenger screen name, no result found on this search. What will be the reason about this problem?
Hi Derick karpoff,
There may be problem in your desired screen name. Try to search with correct spelling or correct name. if it does not work, then uninstall the MSN messenger. Download the latest version of MSN from Internet and install it. Now, try searching in the screen name option.
You will get more information from Internet.
Hi Derick,
There are many possibilities why your messenger’s search bar is not showing any result when you type in a screen name. First, the screen name that you are looking for might not be listed on your contact or does not have MSN or any email account listed. Second, you might be typing the screen name incorrectly. Be cautious of how you spell the name. Third, your settings show only contacts that are online or available. Check the contacts on your setting to make sure that your list will show all contacts. Lastly, your MSN messenger is corrupted. If the problem with the search happens to more than one contact and you are sure that they are listed and saved, un-install messenger and re-install it again.
