abel abel
Posted on - 01/26/2013
I want to take some high resolution screenshots of website and my desktop. Kindly inform me any freeware high resolution screen shots tool. The software or tool should be free and able to take high resolutions screenshots.
Thanks
Searching for freeware high resolution screen shots
There is a software that is supported by Windows XP/Vista/7 which allows users to capture high-resolution screenshots. Name of software is fraps, http://www.fraps.com/download.php
What is advantage is that this software supports video capture, and screen capture in high resolution. After screen capture, image is directly sent to saved file. Works seamlessly and provides desktop capture. There is a free version download, and full version download.
Hope you found this helpful
Hi Abel,
The easiest way to take a screenshot is to use Snipping tool, which could be found by hitting Start button in Windows, then type snipping tool in search field and select it. Another method is a little tricky.
On your keyboard, press Prt Scrn button. Then open Paint in Windows and select Paste. The trick is to capture a screenshot you want to.
Good luck.
