ted hitz
20 points
Posted on - 01/26/2013
Hi expert,
I am website developer. I am facing a problem with joomla manufacturing template. Everything was working fine in past, but now I have transferred to other host. It shows me an error that a XML file is missing. I am unable to find that which file is missing. While my template manager is working normally. Has anyone encounter such type of error? If you know the solutions then inform me. Â
Thanks
Searching for the joomla manufacturing template
Hi Ted,
There are two reasons for your problem first you should check your XML file it has saved completely or not .The second is if it has been saved successfully so you should to go XML file configuration tab and open it and configure it with your requirement because without configuration it will not work properly and gives an error always. Hopefully this information will help you.Â
Thanks,
Raun Nelson
Hi there Ted Hitz,
Two things could cause your problem – incompatible server or uncompleted transfer of the files.
The first thing to do is to open your Joomla backend and to check if you have any warnings or errors there. In case your server isn't compatible with the Joomla version you are using you will have a bunch of red warnings everywhere. The easiest fix for this is the upgrade of your Joomla to the at least 2.5 version.Â
In case everything's fine with your server, you will have to reupload the template files as they have gone lost or corrupted during the transfer. Find the original template package or if you still can download the whole template folder from your old site to your computer. Using the FTP manager connects to your new Joomla site, and copy the unpacked folder inside the folder named Templates.
That should fix your problems,
Drake Vivian
