Searching lost msn messenger screen name
I added someone’s name in my msn messenger contact book but forget now where it is.
Which option is helpful to make possible to search msn messenger screen name?
Hello Priscilla,
Follow the following procedure in order to change the msn messenger screen name.
Take care.
Regard,
Harthy Opera
Here the step-by-step on how you can search you friends on MSN by using your contact list. Log in to your MSN account > Use
MSN Directory and search for their name if you don't know contact's email address > Select Contact> "Search for a Contact" > Advance Search > Fill out form > Remember you could also search for your contact's email-address and mobile number under Contact menu followed by Add Contacts and just follow the prompt provided by your Messenger Wizard.
Notifications
