Searching programs to screen print !
Hi everyone,
I am preparing my thesis report,
I want a programs de prints screen that can help me on Windows 7 64.
(Except standard tools provided by Windows).
Thanks!
Hi everyone,
Thanks!
Hi Bolton Mcfdden,
I would be glad if you want to use the Microsoft's Snipping tool for screenshots and I am just guessing that you don't know that one yet. I have here a program that you can use in getting a screenshot of your desktop.
The software is called, "Greenshot" an automation tool for getting a screenshot with your desktop.Â
You can make a personal hotkey of yours on when do you want to take a screen shot of your desktop.
Hello Bolton Mcfdden,
There is plenty of Screen print software that can help you to do print screen for your report the way you like,
I will make a list for you so you can choose the suitable software you see:
1. Gadwin Print Screen it can directly send the screenshot to your image editor.
2. Jing, you can record your screen and make a video with it.
3. PhotoScape It can add effects to your prints.
4. FastStone Image Viewer it's an image viewer, also a screen print software.
These are the best and easy software to use, and they are completely free.
Hi Bolton,
There are tons of available screen print software that are available for the user's consumption. Below are some of the recommendable software that you might consider on using.
