I need the file for source code mfc sudoku, the sudoku mfc version, which permits to replace the number of colors, or to get any new features. Can you suggest me the mfc programming sudoku source code file and how can I get it, is there are anywhere ready made file or archive?
Searching the source code mfc sudoku file
Hi White,
Sudoku is a logic based game, which is totally a mind game.
Well, you can change or edit the number of colors by it's source code.
There is a application regarding the source code of  mfc sudoku.It is ready made file. Sudoku game MFC source code
And the other website you can check out for source code of mfc sudoku.
Hope you could find your solution!
Hello Willis K White,
As the source codes are the things that are not available for free but still you can get it from the link given below. Here is the rar file from where you can extract and use it.Â
http://www.sourcecodeprojects.com/483151/
Here is the variety of Sudoku source code that can also help you in getting your desired thing. May be some of the things are available in premium version.
http://soft.udm4.com/downloading/mfc_source_code_sudoku/
Hello Willis,
I believe you are looking for the source code of Sudoku game. With the source code you will be able to change number and colors very easily. In the web you could find the source code of Sudoku Zen and Sudoku MFC. I have a link for you to download the source code of mfc sudoku.
http://soft.udm4.com/downloading/source_code_mfc_sudoku/
I hope this helps.
