anonymous
7060 points
Posted on - 09/25/2011
while working on my PC i am experiencing such kind of error. "Sector not found error issue"
I know its related to Hard drives but i want to know exactly What does this error indicates?
What should i do to resolve this error?
AizaM
Sector not found error issue !!
The error indicates fault on your PC. This will occur when disk is bad and disk is dirty and unable to be read.
You should replace the disk for a new one.
There are two major causes of this error. Your disk is bad or computer is unable to read data from your drive. No matter whatever the cause is, this error is indication that your drive should be replaced. If you are having this issue with your hard drive, then off course your hard drive is going bad. There are some chances that you can resolve this issue using scandisk software. This software can determine that which sectors are bad and can also correct these bad sectors to some extent. But this will not solve this issue permanently. To permanently resolve this issue it is better for you to change your hard drive as soon as possible.
I hope this will help you.
