A secure internet connection is required to activate the product (SSL encrypted)
I’m connected to the internet and yet I’m having an error message while installing Avira anti-virus.
I’m going to try and resolve the following issues. If all else fails, what should I do?
Error
encrypted). This could not be established. Please address the following
issues and repeat the product activation.
-Ensure that the Internet is generally accessible
-Ensure that the system date is correct
-Check your modem connection if you are using one
-Ensure that the application fact.exe has access to the Internet and will
not be blocked by a firewall
OK
