Secure Mozilla Firefox using Topark
Hi there
I usually use Firefox browser, I would like to secure browser.
How do i secure Firefox browser using Topark tool?
thanks
Hi there
thanks
Hello, here are some few ways:
1.Change the start page to "blank" or to one that you trust.
2.Uncheck "allow sites" to set cookies.
3. Activate the included no script extension to control which sites can use Java or Java-script.
4.Install Modify Headers or User agent Switch and change your user-agent header to disguise your browser version and operating system.
5. Install RefControl extension to rewrite http_refer to be the base URL of each website.
6. By making these changes to the default Topark, the browser can become ready for private browsing.
Caringal Cheong
I totally got confused between the Torpark tool and the Tor browser because both allow secure browsing and the Tor browser is also using the Mozilla Firefox web browser.
Torpark is a self-extracting file that quickly installs to your web browser. The add-on’s description doesn’t indicate if it is limited to Mozilla Firefox only and in this case, I think this tool will work on any web browser you are using. This tool prevents any pop-ups from appearing and any spyware from being installed without your knowledge while browsing the web.
When you install Torpark, it will add a few unobtrusive buttons in the browser’s toolbar where you can activate and deactivate the tool as well as configure the browser’s privacy settings. This is an effective tool for blocking pop-ups, sneaky installations by spyware or adware, and most importantly it will hide your surfing traces.
But be reminded that the tool’s publisher already cautioned users that Torpark may possibly slow the speed of your internet connection especially if you are using a dial-up connection. But luckily when CNET made a test on this tool it didn’t show any sign of connection slowdowns.
 The tool works on Windows Server 2008, Windows 95, Windows NT, Windows 98, Windows Millennium, Windows 2000, Windows 2003, Windows XP, and Windows Vista.
You can download it xB Browser.
