Secure the PC with fbi moneypak virus removal tool
Hi.
I would like to know the how to secure my PC by using the fbi moneypak virus removal tool? Please let me know the steps to remove the virus through system restore. Thanks in advance.
Hi.
Hi. The steps to use the fbi moneypak virus removal tool and remove the virus through system restore are-
1) Restart the computer
2) In the menu of advanced boot options, select safe mode with command prompt and click enter
3) In the command prompt that appears, type rstrui.exe and click on enter
4) Try to select the date and time just before the PC was infected by the virus in the system restore
5) After the system restore finishes the task, start the computer in the normal mode and then scan the PC using an Anti-malware.
Hope we helped.
