Secure your Files from Intruders’ Prying Eyes
Can this surely keep prying eyes, intruders from getting into your secured files and can't find a way to go around the software or the security key?
Answered By 0 points N/A #141006
It is very important to take care of your system hardware and software resources and important and personal information stored inside. there are some ways you can say as preemptive steps to make intruders a bit tension if someone may succeeded to get access to your personal system.
First of all try to make sure your files which contains important information must be password protected and also important that password used must be in complex form, some kind of mix of alphabets and numbers. you should take care of spyware. Different softwares are available in market to avoid from spyware. if you are user of windows operating systems you should activate and update firewall for your internet security. you can use data encryption tool also to protect your emails and data which you have to transfer online.
