Security Package Specific Error Occurred 1825 On PC
Hey, Everyone! I wondered if someone can help me by providing instructions for solving a security package specific error that occurred 1825?
A) A security package specific error that occurred 1825 is an error that may occur in the windows while using some network-related services. To correct this a security package specific error occurred in 1825; you will need to follow these steps:-
STEP 1. Open the Run window, now type control firewall.CPL
STEP 2. In the firewall settings, tap on the Turn off windows firewall on or off option menu.
STEP 3. Now disable the firewall for all your networks.
STEP 4. Once you disable it, restart your system, and your error will be gone.
B) To fix this a security package specific error occurred 1825; you will need to follow these steps:-
STEP 1.Press and Hit the Windows menu key and the R key altogether to open up the Run dialog box window.
STEP 2. In the search field area of the Run dialog box window, write down ncpa.CPL
STEP 3. Right-click on your Network > Properties.
STEP 4. Now find the IPv4 or IPv6 depending upon your network, choose it, and press on the Advanced menu Button.
STEP 5. Now, go down and make sure that the DNS is correct.
