Security products supported by sapgui tunnel firewall snc solution?
10 points
Posted on - 06/01/2013
What security products are supported by sapgui tunnel firewall snc solution? An SNC secured tunnel is provided which passes through the firewall, which can support security functions such as smart cards, biometrics, etc. what manufacturers offer this hardware and which ones are supported?
