Security Safeguards for Nokia mobile Phones
I like Nokia Phones for their durability and efficiency. My concern all along has been and still is the lack of a mobile tracker in the phones. Is there anything that I can add to my Nokia (xi) to enable this function?
Please help.
Best Answer by Stephanie Clar
Answered By 0 points N/A #158540
You must have heard concerning latest F secure mobile providing of an Anti – theft suite at no cost, it comes with a large bug that this application will simply be uninstalled from your transportable if stolen.
However to not worry, here comes the Phone Guardian that takes your phone security to an entire new level by solving that bug.
With Phone Guardian, you'll be able to simply notice your transportable even with the assistance of GPS tracking system. For doing this all you wish to try to is to tune your internal GPS module or alternatively you'll be able to additionally use network based mostly GPS.
After putting in this application in your transportable, firstly you wish to allow three alternate numbers whereby you'll be intimated concerning the lost phone.
This mobile application appears to accumulate with a host of worthies made options as well as Remote mobile lock and unlock simply with a straightforward sms, not just one however you'll be able to assign 2 mobile numbers for obtaining updates on your lost mobiles.
You'll be able to additionally activate or put off the GPS tracking with the assistance of an sms. When a distinct sim is implanted, its signify out the beep or siren and it automatically locks which may solely be unlocked with the assistance of the password that you have got set initially.
This phone additionally boosts operator specific location data like GPS coordinates and when asked for tracking you'll be able to get data like the range of sim, IMSI, cell id where the phone currently is with a close sms report right into your alternate mobile range that you have got mentioned at the time of initial registration.
This software is absolve to strive for a restricted amount of five days however may be purchased for a little quantity of around thirteen $ from http://www.symbianguru.com/phone-guardian-s60-3.html. This phone supports Symbian Feature pack three mobile phones.
The trial version of the software is restricted to five days. The complete version of the software is obtained by a license code provided upon purchase. The license code relies on the distinctive IMEI provided and therefore the application may be used solely on the device it's licensed for. The license can't recover and used it to different devices.
Answered By 10 points N/A #158541
Hi Marpill,
Why don’t you try Google Latitude Application (GLA) on your phone available free but chargeable as per data plan of your mobile service provider?
Follow these steps:
1. Click on this link to download GLA â€“ https://google-latitude.en.softonic.com/web-apps,
2. Install it,
3. You have to register your mobile number in GLA first,
4. A confirmation link will be sent to your mobile, accept it,
5. Log in to iGoogle,
6 Now you can easily see your phone location (See image below).
You can also add mobile numbers of your friends and if they accept your invitation then their mobile numbers can be tracked on the Google map as well.
Enjoy tracking!
Track on Google Map
