neil guyson
Posted on - 04/03/2013
I got the latest stable phpBB downloaded while I was checking for powered by phpbb free computers security software. But, I have problem in installing it. I am getting an error message stating 'Source Code Error.' I download the file again but got the same error message. Is there any problem with the source code? Can anyone please help me out this problem?
Security software powered by phpbb free computers
Normally the phpBB security software should be downloaded in the mother site and not in the link sites, that is the reason why they were asking and worst security code crashed every time you run the application. Basically, the most essential security software is the Microsoft Security Essentials, its easy to download and doesn't require code. You just have to constantly scan your PC and update the software from time to time.Â
Hello Neil Guyson,
         If you want to use a computer security software and if you are using windows OS then I suggest you to use Microsoft security essentials for your computer protection. The PHP BB software having a source code problem you need to download it again from a fresh link so that you can use it. But MS security essential can give you maximum security and it can get automatically updated no need to get any worries related to that software. The below link can help you in downloading that file so that you can use MS security essential for your PC.
https://support.microsoft.com/en-us/help/14210/security-essentials-download
