I don’t have any more advanced security features that could prefer to our sites would be implemented from my Wi-Fi G routers. Do I need to replace the old-routers with a newer on that could run the Wi-Fi with already a new security protocols? Or should I say does it worth upgrading by refreshing their ROMs with DD-WRT?
Security Wi-Fi G routers upgrade or buy new
What you will need to do first is to try implementing the advanced security features on your Wi-Fi G router before you go to other options such as upgrading. That option should be available in the router security settings, but you will need to note that the advanced security settings may demand that your system have an additional flash memory to be able to hold them. So try that first.
In case the above option does not work, that is when you can now try upgrading the router, or trying another router. But then it will be important if you contact customer support for the router you are using and ask them more about implementing the security settings on the router..
-Mathew Stone
