Seeking help to transfer email contacts.
How to transfer email contacts from my old to new computer?
I have a computer which is running under Windows Vista and using Windows Mail. I purchased a new computer which is running under Windows 7 and installed Outlook 2010. I need to transfer all email contacts from my old computer to the new computer. I will be thankful for your help to get out of this problem.
Answered By 20 points N/A #118846
To export Contacts from your Windows Live Mail to Microsoft Outlook 2010, you need to follow the steps below:
·         Open your Windows Live Email
·         Click on Contacts > Click on Export > Then select ‘comma separated values(.csv)’
·         Click Browse on the CSV export window then select desktop
·         Type WLMContacts on the file name field and click on Save
·         Click on Next and select the fields you want to export
·         Click on Finish and wait for the export process to be completed
·         Close your Windows Live Mail and open Microsoft Outlook
·         Click on Contacts then click on File > Open > Import
·         Select ‘Import from another program or file’ then next
·         Click on ‘Comma separated values(windows) > then Next
·         Click Browse then select ‘WLMContact’ on your desktop then click on Open
·         Click Next and make sure the Contacts folder is highlighted.
·         Click Finish then wait for the process to be completed.
Aristono
