Seeking tips on virtual memory for android devices suggestions
I’m just curious if there is a way to create virtual memory for android devices, just like there is this virtual memory option used in Windows. Is this useful, and how can one make the most out of it? Any ideas?
Best Answer by LyanaHay
Answered By 5 points N/A #148866
Android OS packed with a Linux OS 2.6 Kernel which handles many tasks very effectively. VM Heap Tool is an ideal tool for you to change or decreasing the size of your Android based device. This tool is a user friendly tool so everyone can use it without facing any hassle.
Answered By 0 points N/A #148867
Hi Isaac Ashtonn,
Good news for your query is yes there is such facility available for android device where you can actually get to partition your memory card and add swap memory to it.
To do so there is app available on play store named as swapper search for it and you can use it to create some virtual memory by yourself. But, it may hamper your device performance.
Lyana.
