I am looking for a VBS country code to country converter using the ISO 3166 XML file, from ISO 3166 makes country codes and their respective countries available in both text, html, and XML formats.
It should be possible to use the XML file to provide direct conversion between a country code and its country. For example C#.NET has XML routines, but how would it be done from VBS?
Seeking vbs country code to country converter using ISO 3166 XML file
Hello Mathew.
After doing a littler research I have found a code for you, that will return the country name based on the country code specified.
I am sure this will provide you with the conversion between the country code and the country itself.
Access the link below and there you will find the proper code for your requirements.
Country Code Conversion
VBS Codes – a useful list of VBS codes that might help you do this in another way
I hope you will find this information useful and it will solve your problem.
Randolph
