Seesmic has encountered a problem and needs to close
Hi guys,
I have a problem with my Seesmic Desktop application, while I was using Seesmic Desktop in the middle of managing my social networking accounts Seesmic Desktop stopped working and displayed an error message. I posted below the screen shot of the error.
Seesmic Desktop.exe has encountered a problem and  needs to close.
Seesmic Desktop.exe
needs to close. We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on
might be lost.
Please tell Microsoft about this problem.
We have created an error report that you can send to us. We will treat
this report as confidential and anonymous.
To see what data this error report contains, click here.
Send Error Report Don't Send
After I got the error message, I immediately restarted my machine in hope to get rid of the error, but after doing so, I am back into managing some social networking accounts, after a short while same problem persisted, please help me figure out on how to get rid of this persistent error, thanks a lot.
Best Answer by Boweee0
Answered By 0 points N/A #98189
The reason why you got that error message is the conflicting resource usage of the program you are using. Make sure you close all unnecessary programs to avoid such conflict. Here are the few tips to consider in optimizing computer programs' performance.
  • Disable services you do not need. For more details please visit this link
  • https://answers.yahoo.com/question/index?qid=20061006222447AAHbGdQ
  • You can also try msconfig to disable services that are less needed on your daily activity. On the start menu select run and type msconfig.
  • Start up programs could cause conflicts and thus using most of the resources. Try to disable it via msconfig. On the System configuration utility click startup and uncheck the programs you don't need or simply just click Disable All.
  • If all of the above fails, reinstall the application by just running the setup file again and chose repair.
Answered By 10 points N/A #98190
Hello Danny,
To resolve the issue that you're getting, you will need to try uninstalling the AIR runtime and after that re-install it. Another thing you should try is contacting the developers of these applications to find out whether the issue is related to issues they already know about.
Otherwise, the desktops.exe is usually a Windows file that is created by the Totalidea Software. That file can be found in the following location on your computer: Program Filestweakvi folder. In case you find it anywhere else apart from the location that has been indicated, note that the desktops.exe could be a virus, Trojan, worm, or spyware. So you will need to perform a system scan using the antivirus you have to get rid of it.
Carl
