SEFI6 Wireless product made by Wolfpack Systems
Can anyone tell me how this product might help in case of the security and defensive sector of any country which might be using this product in the security and defense sector?
This product is made for industrial use specifically in the petroleum and chemical industry. The safety and security that they are talking about here is that during the transmission of data wirelessly, it is possible to ignite flammable materials since theoretically, under very precise conditions, it is possible for a spark from a certain system’s battery to ignite gas vapor. This system eliminates that possibility that’s why it is safe and secure to use even in hazardous condition such as that of a chemical factory. With regards to the defense sector, a different type of security and safety is employed such as safety from data being intercepted.
The SEFI 6 wireless data transmission system is a wireless technology that permits digital and analog signals from whichever monitoring device to be read and transmitted from a location at risk of explosion by means of a high performance wireless connection. It can be integrated into a remote monitoring system to be able to transmit data which involves battery status, alarms, or other service data to a main server.
The system does not need cable ducts which lessen work in hazardous environment. Allows savings because the need for excavation and expenses related to authorization and planning is no longer necessary. This is the perfect solution for those hard-to-reach areas or areas at risk of explosion. The system doesn’t need active important safety barriers. It is capable of tracking up to twenty devices in parallel.
