SEGA – Error 503 Service Unavailable
Hello
I got the following error message. I need to solve it. Please help me to find a solution.
Thanks in advance.
Hello
Thanks in advance.
Hello Hunter,
To resolve that error, do the following:
The issue is usually associated with the application pool account of a SharePoint website. You may need to perform some more R&D. That will depend on what you did last before you got the error.
Hope this helps.
Carl
Hello.
You’re getting these errors because of the following reasons.
1.      The website you are using may be temporarily down.
2.      The other reason may be, the site is under maintenance.
3.      Servers to the site may be busy.
4.      Check for your internet connection whether it is connected properly or not.
5.      Try to access the website after sometime.
Thank you.
