LuciaD
Posted on - 10/23/2011
Greetings to everyone at Techyv!
I've installed an upgrade of Avid software on my desktop. When I ran it, this error came up.
I used an uninstaller to remove the previous one, with a hunter mode to clean up remaining files.
What could be the problem here?
Thanks guys for any help.
Segmentation fault” in thread “Main thread”, at address 0x0
Segmentation Fault in thread, at Address 0x0
Although Mac system is supported, your system is required to be in 64-bit version.
Otherwise, the application will still don’t work. Since you did not mention in your post about your computer’s specifications, read the information below about Avid Media Composer 6’s system requirements:
Windows
Windows 7 Professional Service Pack 1 64-bit
Intel Core 2 Duo 2.33 GHz or higher processor
4 GB RAM, 6 GB RAM recommended
NVIDIA Quadro FX 560 or higher video card
80 GB free hard disk space
Mac
Mac OS X Lion 64-bit
Dual Core 2.66 GHz or higher processor
NVIDIA GeForce or ATI Radeon video card
80 GB available hard drive space
See the details above if it matches your computer’s hardware specifications.
If your hardware qualifies to run it, try uninstalling it and then install it back to have a fresh configuration.
Try not to use any third-party application for uninstalling this program.
