Seiko SLP Client Port Monitor Error.
I'm using Windows XP. Every time I start my computer, I receive an Error message, "Seiko SLP client port monitor encountered a problem and needs to be close".
Seiko SLP Client Port Monitor has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in the middle of something. the information you were working on might be lost.
For more information about this error. click here.
I'm facing this problem for about 4-5 days. I have checked the Hardware Monitor, but nothing looks wrong there.
Other functions of my computer seems to be fine.
Best Answer by addison gray
Answered By 0 points N/A #119061
Seiko SLP client port monitor is from the Seiko SLP printer software, it is not visible and a file that not recognize in the folder of Windows. When SLPMONX.EXE  file is located in the folder of C:/Windows/System32 or C:/Windows, there are possibilities that viruses, spyware,  Trojan,  and malwares are hiding as SLPMONX.EXE  even some of the application or files in your systems.
So you should check or scan your computer if there is any errors hiding as  SLPMONX.EXE  if you found one, try to  remove the  SLPMONX.EXE  file in the folder C:/Windows/System32, after that restart the computer. I suggest that get some “Security Task Manager” to check up on the security of your computer device.
Answered By 0 points N/A #119062
You can go to C:/Windows /system32 folder then delete the SLPMONX.EXE file then restart your computer and before doing that you need to check the SLPMONX.EXE process in your computer if it is pest o you can download Security Task Manager from here https://www.neuber.com/taskmanager/index.html?ref=file.net   for Verifying your computer Security hope that may help you
