Select User or group error with selected objects
Configuration Manager 2012 setup fails at Prerequisites Check with Error “Failed to connect to registry on machine SQL (FQDN)”. I cannot solve this so is there anyone who might help me please ? What could be the problem ?
Thanks !
An object (User, Group, or Built-in security principal) with the following mane cannot be found: “sccmdomCAS1$”. Check the selected object types and locations for accuracy and ensure that you have typed the object name correctly, or remove this object from the selection.
Close
