Selected file does not appear to be supported by Adobe Flash Player
I am running Mac Operating System and sometimes use older version of Flash Player to play files containing different formats. The following error message appears on the screen when I select a file to play. How can I fix this issue? Suggest me. Thanks.
The selected file does not appear to be supported by Adobe Flash Player, although it may work for custom uses such as mobile devices. If necessary, launch Adobe Media Encoder to convert this file to a supported format such FLV or F4V.
