I'm using Semcad X Light. I have no problem using the CreateSkinBody command. With a sequence of circular arcs, I can create a model profile which is obtained from a cutting tool. If I try to do the following using Python I receive the following message:
s=SEMCAD.model.CreateSkinBody(ProfileList)
TypeError: No registered converter was able to extract a C++ pointer to type class api::CBody from this Python object of type Entity >>>
Using the circles I have exhausted all possibilities I can think of. Thanks for those that can help.
SEMCAD TypeError When Using Python
If you are new to this application, check again the documentations that came with it. Or, you may just visit speag — SEMCAD X Light V14.4.4 Released. The information posted on this page applies only to SEMCAD X Light V14.4.4.
If you are using this same version, please read the information carefuly to fully understand the complete functions and limitations of this version.
You may also try doing a clean installation of the program again to fix any corrupted files that may have developed during its previous installation. Uninstall your present version of SEMCAD X Light then restart your computer when asked.
After booting, check your machine for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your computer, use a disk utility application like Norton SystemWorks.
After this, install SEMCAD X Light again then do a test if you are now able to use it.
If you are using an older version of the application, you may also try upgrading it to the latest version. SEMCAD X 14.8.1 is available and works with Windows XP 32-bit and 64-bit, Windows 7 32-bit and 64-bit, and Red Hat 5 64-bit.
To download this version, you may visit speag — SEMCAD X — SEMCAD X 14.8.1.
