Sencha Touch timetable i.e., adding of an Event Listener
Hello Techyv Guys,
I need a small support from Techyv Experts, Please do the needful for letting me know about Sencha Touch timetable i.e., adding of an Event Listener. Please do the needful for explaining me along with a sample coding for a better understanding.
Thanks and Regards,
Neil Rabon
Answered By 0 points N/A #181837
Sencha Touch Calendar are plug ins that enable you to add calendars to your Sencha Touch applications. An example code would be:
Ext.define('XXX.view.NavigViewTimetable', {
        extend: 'Ext.navigation.View',
        alias: 'widget.navigviewtimetable',
        requires: [
        'XXX.view.TimetableContainer',
        'XXX.view.DetailView',
        'XXX.view.TimetableEdit',
        'XXX.view.TimetableDayList'
        config: {
            navigationBar: {
                items: [
                        xtype: 'button',
                        text: 'Add',
                        itemId: 'addButton',
                        ui: 'custom-btn-up-timetable',
                        align: 'right',
                        hidden: false
                ui: 'custom-toolbar-top-1L'
            items: [
                    xtype: 'timetablecontainer'
                //Toolbar
                    xtype: "toolbar",
                    docked: "bottom",
                    ui: 'custom-toolbar-2L',
                    items: [
                            xtype: "button",
                            text: 'Today',
                            ui: 'custom-btn-dwn-timetable',
                            //handler: this.onTodayButtonTap,
                            //scope: this,
                            itemId: 'todayButton'
                            xtype: 'spacer'
                            xtype: "segmentedbutton",
                            items: [
                                text: 'Daily',
                                text: 'List',
                                //disabled: true,
                                pressed: true
                            itemId: 'segBtn',
                            align: 'right'
            listeners: [
                    delegate: '#addButton',
                    event: 'tap',
                    fn: 'onAddButtonTap'
                    delegate: '#todayButton',
                    event: 'tap',
                    fn: 'onTodayButtonTap'
                    delegate: '#segBtn',
                    event: 'toggle',
                    fn: 'onSegBtnToggle'
            // I NEED ADD LISTEN TO AN EVENT HERE
            title: 'Timetable XXX',
            iconMask: true,
            iconCls: 'XXX-icon-timetable'
        onAddButtonTap: function () {
            console.log("addItemCommand [NavigViewTimetable]");
            this.fireEvent("addItemCommand", this);
        onTodayButtonTap: function(){
            console.log('onTodayButtonTap [NavigViewTimetable]');
            this.fireEvent('todayButtonTapCommand', this)
        onSegBtnToggle: function (segBtn, btn, isPressed) {
            //console.log("'" + btn.config.text +"' on segmented button pressed" );
            if (btn.config.text == 'List'){
                this.fireEvent('listToggleCommand', this);
            }else if (btn.config.text == 'Daily'){
                this.fireEvent('dailyToggleCommand', this);
However, I would instead recommend using Controllers than putting codes. The advantage being that with Controllers, you are able to avoid the continuous maintenance of updating the codes. Another advantage is you will be able to use action configs for the buttons. For example:
xtype: 'button',
                    text: 'Add',
                    align: 'right',
                    hidden: false,
                    action:'addButtonAction'
Also, control config option can be utilized such as:
                    Ext.define('XXX.controller.ButtonController',{
     extend:'Ext.app.Controller',
     config:{
          refs:{
               views:['Theviews.youwanto.refer'],
               //addtional references
          control:{
               'button[action=addButtonAction]':{
                     tap:'functionForAddButton'
     functionForAddButton:function(){
          console.log('Add Button tapped');
