I am having OneNote 2010 with me, I used to use the feature Send to OneNote in Internet Explorer. Heard that Google chrome will also support this feature, I am having the latest version of Chrome but no idea on how to use the feature Send to OneNote. Is there any separate Plugin or extension for that. Please advice on how to get the feature Send to OneNote Chrome. Thanks
Send to feature in OneNote Chrome
You can use your OneNote with Google Chrome as well. To activate this feature you need to download and install the extension. After installing you would be able to use OneNote with your Chrome. You can find the coding or extension file online. It’s always safe and easy to find desired extensions from the link below:
https://chrome.google.com/webstore/category/extensions
Since your using One Note 2010, now Download and install the IE tab google chrome extension.
Then click on the IE tab icon on the web page you want to send to One Note and when a second address bar appears, just right click anywhere in the page and select send to one note.
And that is all, the page will appear in one note and you will be good to go.
Good luck.
