Hello expert, my friend asked me how to create and send a flash animation email by using hotmail ID. Please can you suggest me about creating a flash animation email and how to send it? Than I can explain my friend.
Send a flash animation email by using hotmail
Greetings! If you wish to send an animation via email using your Hotmail account and Hotmail ID, simply log in to Hotmail, then click Compose or New Message. Find the attachment button where you can upload files not only animation but a lot more. Please take note that there is a limit to the size of per file uploaded. Upload your animation, enter a subject in the Subject line and recipient/s to who the file will be sent. Then press Send. In cases that you cannot upload the animation file, you can put it in an archive and upload it. Again, make sure your animation file size is not too large. Hope that helps!
Hi Sammd,
Good day!! After download and install the design panel, start the Flash Pro and open the “DragonBones_tutorial_Start.fla” file in source code package.
· Open the library panel in Flash Pro and you can see the related symbols
Double click the MovieClip “Dragon” in the library panel to enter the edit mode. We need to understand how this animation is structured, which can help edit the skeletal animation later.
After getting all of the requirements above ready, you can click Window>Other Panels>SkeletonAnimationDesignPanel in the Flash Pro menu to open the design panel. We will explain the details about the usage of design panel in following steps.
Click the “import” button in this panel, then you will see the following pop up window for more information visit …
https://dragonbones.github.io/en/index.html
Thanks
