Sending a FAX without having a FAX machine.
I do have word documents / scanned documents on my machine. I have to FAX them but I do not have the FAX machine.
So will it be possible for me to send a FAX without having a FAX machine ?
Sending fax without any fax machine is very simple. You can send fax without using fax machine through different online fax programs.
Checkout some of the websites below
MaxEmail.com
MyFax.com
FaxZero.com
RapidFax.com
These are some of the online faxing services, signup from any of these programs.
After signup and confirming your account, login to your account
Follow instructions to upload your saved document or image and then send your fax.
It is that simple.
this is very nice option because you do not have to tie up the phone line and also doesn’t need to buy expensive fax machine. this will also help you saving time and money.
Hello Schadhari,
Yes it is possible to send a fax without having a fax machine. There are few online services that offer free fax service. So ho does it work? The answer is simple it actually allows you to send an email to a fax machine. You do not have to register yourself it's totally online just go to the website fill the form with required information, upload the file to be sent. As i told you it's free.
Here are few web services that offer such services.
1- gotfreefax
2- faxzero
3- popfax
Try any of them. They works fine and free to use without any registration.
Thanks
