Is a Sending a High-memory file possible?
I have a large file for about 1gig.
How can I send this file and what application am I going to use?
It is possible to send a large file.
I was sending large file and honestly forgot how big the file was I just cant send it even I zipped it.
That was when I send a converted file in a dropbox and shared it only to the person I have to send those file. Â
You can deliver any large size computer file through your e-mail account easily. But you should follow some techniques to do it. Let I recommend you the way to deliver any large file.
 If you want to deliver a large video file then you should divided it as 10-20 parts. Then you may try to deliver it aspect by aspect. You can make part by use video splinter software. Just add your video in splinter software and then take attempt to send it after making video parts
And then create zip data declare each aspect by use Winrar of WinZip application.
You can send up to 2GB file through dropsend. I think their feature may solve your problem.
Thanks
