Is there a possibility to send multiple emails without using a coded program or Outlook? I don’t know much about programming. It just gives me a lot of errors. My outlook doesn’t work.
It also has lots of error. I hope someone has an idea of another internet application (not any software to purchase) for me to send multiple emails.
Sending Multiple Email for Online Marketing
Hello Kenny,
I have read your concern on how to send multiple emails. As what I’ve understood with your question, you wanted to send multiple emails via Outlook but you are having problems though. That’s why you’re asking now for a program which can easily be downloaded online. Is it right?
The problem is with your Microsoft Office Outlook and not with an application that can send multiple emails. Microsoft Office Outlook is already capable of doing that. You just have to fix it to restore it to its working condition again.
Try reinstalling it. Uninstalling Microsoft Office Outlook then restart your machine when asked. If it is part of Microsoft Office package, uninstall only this feature.
After booting, install Microsoft Office Outlook again then see if this fixes the problem.
I hope I am in the right track of understanding your concern and gave you a hand to fix the problem. I hope this information is of good help.
Good Luck!
Mali
