Sending SMS to a Mobile Phone via E-mail
I need to send some SMS messages through e-mail. Is this possible that they’ll receive it as a text message? Most of my contacts are AT&T.
It is possible. It is as simple as sending an email. The only difference is that you change the format of the address to [10-digit phone number]@txt.att.net.
Example: [email protected]
Not only that, you can also send SMS to most of the networks other than AT&T. You can check this website: http://sms411.net/how-to-send-email-to-a-phone/
It is simple to send the message such as text  from email to AT&T phone. Just add [email protected] desire phone number. Such as [email protected]>[email protected]
You can check message by using this side this website: http://sms411.net/how-to-send-email-to-a-phone/
