Seo tool bar is not showing after installation
I have recently downloaded Alexa toolbar for SEO job purpose and now I cannot find it in my internet browser. I need to find it in my Mozilla browser or rather I should say I need to enable it so that I can see it.
Should someone know where to find it kindly let me know.
Arnel Bui
Answered By 0 points N/A #109564
Here are some suggestions that might solve your problem:
  • Check if the Alexa is in your list of toolbars. You can do this thru View in Menu (ALT +v) > Toolbars.
  • If it’s in there but there is no checkmark beside it, enable it by just clicking on it. However, if it does have a checkmark already, then there must be some other problem. I have a link from the Firefox help site that can help you fix this problem.
  • If you have checked the Toolbars menu and the Alexa toolbar isn’t there, the possibility is that it wasn’t installed properly for a reason – You can go check Tools > Add-Ons > Extensions and try to see if it was really installed. You can also go check the Firefox support article on troubleshooting extensions and themes for in-depth solutions or you could also check the Unable to Install Add-Ons support article for additional reference.
Note: You could also check which version of Alexa you’re using – Try to use the fully updated version to avoid problems.
