Serial Key for Deep Freeze Standard for Win Vista
Where can i find a FREE License Key for Deep Freeze Standard for my Win Vista.
I am using only 30 days trial.
thanks
thanks
Dear Mehnic,
DF can be used to prevent program corruption and prevents virus to corrupt your program. This is designed and configured to REFRESH or REGENERATE its original system when you RESTART the computer.
Means, once you run the DF: EVEN the virus or bug corrupt your OS or you lost or delete something, by restarting the computer, it will recover the lost files by the time you activate the DF.
DF driver protects everything in your DRIVE C and its operating system that are important tot he program files. You can access the DEEPFREEZE by "HOLDING Together” the "SHIFT+CONTROL+ALT" key then press F6 in keyboard.
Then the DF will POP-out instantly and there, you can now access it by your password. And there you go; you can now freeze your system drive.
If you want to uninstall it, just run the installer. You can download the latest version of Deep Freeze from.
Just select the appropriate version for your operating system.
Hope this will help a lot.
The Solution is EASY at Techyv.
